***Flap Discs, Flap Discs, Flap Discs!!!
Roark Supply
Supporting Vendor
…and some cut off wheels, to boot.
It’s our Flap Disc and Cut Off Wheel Combo Deal featuring Premier Grind 4.5" zirconia flap discs (German Made) and SELECT CUT 4.5” cut off wheels.
Priced at $35, this package includes:
25 – Premier Grind 4.5” x 7/8” Type 29 Zirconia Flap Discs: 10 - 40 Grit, 10 - 60 Grit , 5 - 80 Grit, and…
25 – SELECT CUT 4.5” Cut Off Wheels: Type 1 (flat)
***Roark Supply is a leading provider of abrasives used by fabricators, as well as off-road and custom car enthusiasts.
woody
unhelpful spotter
Staff member
Admin
Toquerville UT
Q? What flap discs do you recommend for a cast iron diff carrier? Or, something other than flap discs??
Somebodyelse5
Land Crushers
Phx, Arizona
can you guys suggest a flap type for general fab work? Type 27 or Type 29? Or should I get a mix?
Killer deal, will drop in an order later today!
Roark Supply
Supporting Vendor
1922576
T27/Flat - Used when working on flat grinding surfaces, primarily for blending and smoothing
T29/Beveled - Slightly angled,, which is helpful for contour and edge work. The experts say this is "the best choice when speed and stock removal are primary considerations".
Roark Supply
Supporting Vendor
There's madness in the air...although we're not sure how much longer our Combo madness is going to last.
Roark Supply
Supporting Vendor
March Madness is in full swing and so is this Combo Deal.
Don’t miss out!
Drake2
Wisconsin
25 – Premier Grind 4.5” x 7/8” Zirconia Flap Discs: Type 27 or Type 29 / 36, 40, 60, 80 or 120 Grit, and…
Same drill as usual…Use the COMMENTS section to let us know types and grits for the flap discs. If you leave this blank, we'll send T29 /10 - 40 Grit, 10 - 60 Grit and 5 - 80 Grit.
Hello, what products do you recommend for removing paint and bondo, but not metal, from a body tub? Thanks.
Roark Supply
Supporting Vendor
Father’s Day is behind us, the 4th of July is ahead and the Combo deal is still available…for a short period of time.
The combo deal will end Sunday, July 7 at midnight PDT.
Don’t miss out!
Roark Supply
Supporting Vendor
Back for just a short time, the Combo Deal is available until Monday, September 2 at midnight (PDT).
We’re not sure if or when we will bring this deal back again, so don’t miss out!
