Hello,
I am coming here after being stumped on my 1992 FJ80 with the 3FE. Here is a youtube video showing the problem.
The main issue that the engine surges about 200-400 rpm under little load and the problem is getting worse.
Initially, I thought it was a torque converter lockup issue but I have now forced the issue to occur even in neutral -- not the transmission.
The problem is definitely worse when the engine is hot. If I hold the pedal at about 20% down, it will struggle, but will make it. If I go past that, it surges and bounces. It feels like an on the power off power surge. When its not making power, I can push the pedal all the way down and get nothing.
So far, I have checked the TPS sensor - I measure about 0.7v when at idle and about 3.8v when wide open and the idle switch works.
The AFM I have checked with an oscilloscope and can see a smooth sweep of position.
I have done the FSM check of the ignition coil - I get 0.4 ohms on the primary, about 13.5k on the secondary.
I tested fuel pressure a few weeks ago and saw 40psi continuously. I'll be checking again tomorrow.
When shorting TE1 and E1, I see code 15 -- ignition fault.
Any ideas or good next troubleshooting steps?
