Just a few rambling questions before I install Matt’s newly minted thermostat housing sensor array:
1. Note the two identical FJ62 Upper Thermostat Housing casting numbers in the attached photo. One shows a #4 and the other shows a #2. Does anyone know the significance between the two numbers? Just curious.
2. I thought I read a historical post where the electrical sensors gain a grounding function when the male threads of the sensor contact the cast aluminum threads of the housing. Hense, DO NOT use pipe tape or any thread sealant…TRUE or FALSE? ( I’m aware that aluminum has less than half the conductivity of copper but it’s non magnetic alloys still make it a true grounding option.)
3. If not using pipe tape or thread sealant, can I use a copper based anti-seize lubricant on the sensor threads?
Any thoughts?
Any thoughts?
