FJ62 Door Lock Issue (1 Viewer)
Raleigh, NC
Hey All. I've read a lot of posts about the power lock issues. This is partly that, but I'm having issues with locking the door manually.
Backstory: When I picked up my 62, all the power locks worked correctly, except the rear passenger door. They have been on my list for a while, but not a huge priority. Today, I had some new keys cut and to test them I was going to lock the driver door and then use the key. The power lock isn't working on the driver side (no shocker), but I cannot even get the manual lock to budge. Interior and exterior handles work great. Very strange.
I haven't opened the inside of the door yet because it's freezing and I'm tired, but will do that this week. What are the potential causes of this issue? Worked fine last week, why an issue now? Could the power and manual issues be connected? What should I be focused on while I'm in there?
Thanks in advance.
Did you cut the key from the ignition key or use the code from the passenger door? Your drivers door might have had the lock replaced at some point
It was cut from a key. The key works on the passenger door. The issue is the this piece won't go up and down, even with my hand.
Either the plastic lock tab is jammed on something or the "bell crank" pivot is locked up due to the pivot point, or possibly the rod that runs back to the latch/lock is bound up. just need to take the panel off and investigate. The lower rod is the latch release, the upper is the lock.
Thanks. I'm not sure what any of those parts are, but I have a feeling they will become more obvious when I open the door. LOL
View attachment 3821451View attachment 3821452
While I'm in there, I will probably clean it out and apply some grease. I've heard of moly and lithium grease recommended in the past. Is one better than another in this situation?
That area is not sealed from water. Use lithium.
Perfect. Thanks!
It's been sitting outside in freezing temps this week. What are the odds it's just frozen in there??
So, I opened the door today. I think there's a mix of problems that were causing the lock malfunction.
  1. There was moisture in the mechanism that likely froze it. Like I said it has been out in the sub-freezing temps.
  2. It was dry as a bone. Over all it was clean, but that whole thing could use some grease. So, I'll lube it up this weekend. :rofl:
  3. The rod that actually moves up and down ("shown" in red) has a bit of a curve in it. Is this normal?
Just had a look at mine here is Sunny Oz and you should be able to grab the actuator output shaft and move it up and down freely. Should move about 20mm.
It moves now. The rod just has a slight :banana: to it. I'm currently tearing the inside apart to install sound deadening and Orikawa door panels. So, everything will get a good lube and hopefully won't have problems long-term.
suggestion :
go to dealer and invest in every single , OEM Pink , Glow Stick green , Blue smurf , ROD and linkage $1.88 or less part "s you can obtain
its like lunch-money over all out-of-pocket level , but , the time you spend making this happen , will seem like the sand-of-Time frozr ....
however ....
new moving oem color keyed nylon separating all the 45+ year old metal stuff will glide like a dream and be a happy-forever parts topic you will never have to re-visit for another 45+ years ...
make sense ?
oh ,,,, , and no Chairman MOE-Spec. market region cracker-jack-smack off AMAZON either ,
that is going backwards in evolution ..
there is no Day-Dreaming permitted here , all the chairs and desks are always only in the front row of my Class-Room & Laboratory :D
81-90 Toyota Land Cruiser FJ60 FJ62 REAR RIGHT Passenger Door LOCK Rod OEM - Picture 1 of 2
Restored Rear Tailgate Linkage Assembly for 1980-1990 6x-Series Toyota Land  Cruisers
Restored Front LH Door Locking Solenoid Assembly for 1987-1990 FJ62 Toyota  Land Cruisers - BTB Products - Land Cruiser Restoration and Parts
Thanks man!
i follow anything 60 series anything if the word LOCK is involved , you had DOOR also ...
once i had a moment to review what you were going at here ? i then knew what tech. media to post that would help you along the most ...
What in the heck are these ?? made me 5-mile-smile 🤣 ...
but i was also being dead-nutz serious about the pocket change low cost involved to make this happen and the also taking the time to make the time to re-new / re-fresh any piece of nylon / plastic Toyota offers up ....
it's one of those odd parts topics where sh#t is actually reversed : low cost parts but notable more time spent at the toyota dealer parts counter ....
in the end i rate it as a value over the time spent =
win ......🔧
side on-topic :
your thoughts 💭 on the below ⬇️ new reality …?
Toyota founded and owns Dihatsu outright , you should google-up the
“ Land Cruiser Blizzard “ 🥶
