So, I have been searching for the 2LO mod for the 62's and haven't found anything other than, "try this, it should work". I decided today to try the 2lo mod and it worked just as advertised in my driveway.
First I located the L4 switch (PS of the TC) that tells the vacuum switch to engage the 4WD. Its the one with two wires to it.
Then I followed the two wires and disconnected the connector on top of the TC.
Last, I taped up the plugs and put them back in their wire clamps.
So there it is, shift from 4HI to 4LO and no light and only the rear wheels have low range power, hit the 4WD button and your in 4LO, shift from 4LO to 4HI and your in 4HI. Just remember to shift the trans to neutral before shifting from HI to LO.
I will be testing a little more this weekend in the dirt.
