I have a few issues at the moment one being a leak from the power steering. I thought it was coming from the steering column input but today I just noticed this tube coming off the bottom of the power steering pump that is just capped and is leaking from the end, I think the pipe clamp cut through the rubber cap. Anyone know what this tube is for and why it would just be capped? I guess I’ll just try to find another cap? Any other ideas?
On another note I’ve been struggling with vapor lock for too long and everything I do thinking it will fix it doesn’t fix it. The weird thing is it didn’t do it when I first got the truck but then started. It’s hard for me to pinpoint what could have changed around that time. I changed the mufflers and I thought the new ones were larger and closer to the metal fuel lines so I rerouted them. Didn’t help. I also replaced the inline fuel pump and filters in a parking lot while in colorodo. Seemed to help but it’s still doing it sometimes.
The only other thing that was changed was the water pump and thermostat. I think it had a 160 degree and when I had Chevy replace it they put in the stock one which I think it 184? It also seems to run hotter lately and I sometimes even have to turn off the ac or it will keep going over 210. Never did that before either. But from what I’ve read either thermostat should be wide open at that point and act the same. Should I try putting a 160 back in? I think the vapor lock is happening in the engine bay. So I need to figure out how to cool it down in there. I run a scan gauge and never let the engine get over 210. Usually it runs 195 with no ac on.
As far as the vapor lock symptoms. It won’t start up on the first turn of the key after it’s been running. But will always turn over second try. If I’m doing long mountain passes is where it will start to happen while I’m driving. Acts basically like it’s running out of gas. Wait a few minutes and it fires back up.
Any help is greatly appreciated. I really want to get this truck sorted and on the road.
One last thing. There seems to be a ton of heat coming in by the front driver and passenger foot wells. The transmission is running cool and I lined the floor under the carpet with reflector stuff but it still almost feels like the heat is on. Any other idea to keep the heat out.
Should mention it’s got a 6.0 vortec and 4l80e transmission. The conversion was done before I bought the truck.
Cheers!
Jason
