FJ60 Snorkel Options for LS Swap
Anyone know if there are any options that work on a 60 for getting more air into the engine. Have the Safari Snorkel right now, but after an LS engine rebuild, my mechanic is suggesting that the snorkel may not be let enough air in. Maybe a snorkel with a larger air tube? Anybody come across this? Thanks!
it doesnt actually matter, it still has to go through the small throttle body opening. Have you ever actually took your stock throttle body off and seen how small it necks down to? It's about 2"
Has your mechanic checked airflow values over the MAF sensor with the snorkel installed vs without, and driving vs idling still, yet? That should give you a good indication of what the actual difference will be.
We haven’t yet. build is just about done. In my research the throttle body is right over 3”. Just a concern he brought up to me about the snorkel maybe choking the airflow since it’s a smaller diameter than my hoses.
I wouldn't worry about it.
well, if a 2f has got issues, physics tells me a warmed over 6l is gonna be pissed trying to breath
All the vortec, LS and even the Sonoma/s10 V6 motors, pre-LS2/3 anyways, have the same throttle body design. So no.
@cruisermatt come on bro.... if thats so take the big intake stuff off your swap and reduce it down to 2 1/2 and report back about how much better you like it and then I'll tell you not to worry about it. This has already been done on a swap i did owner went from 3 1/2 all the way to a big kn style filter to the 62 box with an 80 lid on it and reduced everything down to the 80 lid and there was a big difference in power lq4 with a cam swap around 409hp that is a real world test.
i did. Ran it with bare throttle body and with my filter setup. No difference from the driver's seat in my opinion. Either way this is all just our opinion from driving. I haven't seen any dyno results. Even if there is a few horsepower to be gained I don't see the need to make a custom snorkel or anything like that. Either way I like the way you made the big inlet into the 62 airbox.
Thats basically what i said in my previous post that all the big intake stuff can be done but at the end the snorkel will still be the limiting factor just like the small intake port into the 62 box its small af but plenty for a 3fe. If someone is willing to pay i am sure a larger snorkel can be made but not sure how it would look. @sixtyseries do you actually need the snorkel? Or just want to keep it because its already there?
More just because it’s there. Wouldn’t mind making a small effort to keep it functional, but not the biggest concern for me really.
Cool would still like to see some pics once you get it back in your hands either way it will still be double the power double the pleasure double the fun.
Yep, sure will! This actually all started when I found a crack in my block. So, it had been swapped before this. Went ahead and swapped to an aluminum block and made some power upgrades along the way. thanks for the convo guys!
