So I replaced my radiator, fan clutch, water pump, belts, and hoses. It runs fine but seems to run a little warm. I went out for a hike and on the drive up (6am 85 degrees) it ran just over 1/2 to 2/3 on the temp scale. On the way down (1pm 110 degrees) it ran a little cooler until I reached town. Once in town it runs hot, at stop lights it goes almost to the red. This has happend the last couple days around town.
Before the work was done the temp was always at the bottom 1/3. What could be causing the higher temps?
I replaced the thermostat last year but have not changed the radiator cap. The fluid levels seem to be fine, I will check the belts in case driving around a couple of days has loosened them up.
Anybody have any idea? I thought this was a sign of the fan clutch going out. What is the warrently on a new part from Toyota? I am at a lost here.
Sean
Sean
