FJ60 not starting, but will run with bump start - gas smell, new plugs
Salt Lake City, Utah
Hey all,
Having some starting trouble. Earlier, drove the car to town and it was totally fine. Turned it off for 45 seconds - as much time as it takes to run up to a porch - and when I got back, wouldn't start. Got it started by bumping it down the hill, and it ran totally fine all the way home, and normal idling at stop lights. Now it won't start again, even when being jumped. It will only start and idle really rough if you hold the gas pedal down while cranking. Then if you let off the gas it will die. When trying to start, has a really strong gas smell and some sputtering black smoke out the tailpipe. A few things of note:
- It's got a brand new battery in it but the "volts" gauge on the dash is low (bumps up a bit and hovers around 12v when jumping it)
- Sometimes when we turn it off, it will sputter for a few seconds before dying.
- Just replaced all spark plugs and wires tonight.
- New engine air filter
- New clutch master cylinder & slave cylinder (this wouldn't be the issue, but maybe we bumped something while we were down there?)
- Plenty of gas - definitely hisses when you open the gas cap
Any insight much appreciated! Happy Friday!
Really strong gas smell and sputtering black smoke sounds like too much fuel. Check the fuel level in the carb sight glass. The engine will not run if it’s drowning in fuel. I had a similar situation when my float failed and filled with fuel which caused it to sink and pumped too much fuel into the bowl. HTH
I checked that. Level right in the middle of sight glass. Engine will run, it just won’t start
Have you checked your FUEL FILTER?
Will it start on choke? Is your fuel solenoid connected? Especially if doing work around the master cylinder area, could’ve disconnected this. Then it will run on choke but not idle or start normally.
For this instance in particular...
Start a hot engine differently. Push the gas pedal to the floor once and hold it there and DONT PUMP IT.
Then crank the starter with the gas pedal still held on the floor until it catches and runs.
If the carb fan doesnt turn on automatically at engine shut down, this would cause the above scenario.
Dont pump the gas pedal on a hot engine
Nope, wont start with choke or no choke. I’ll check fuel solenoid.
Thank you. I don’t think I pumped gas but maybe did out of habit. Carb fan was definitely on when we went to start it again.
  • Like
Reactions: OSS
Not yet. Would this cause problems while running, or just when starting? Because it ran normally when we bumped it
Yes, a bad fuel filter could cause your symptoms. If you have the type filter where you can see in/around the filter just check if debris is sitting at the bottom.
And if not, new fuel filter for a 60 cost maybe $15 and takes 5 minutes to install.
