am I able to use plastigage without new bearings? or should i take one of other cylinder bearings and put on 1st cylinder then use plastigage to determine what size I need?You can use plastigage to check clearance
Did you replace all the bearings?i took off the oil pan again and took a look around, everything looks good except for 3rd cylinder rod which have side to side play but no up and down play. I am going to disassemble the 1st cylinder and measure the gap
ok guys, I have replaced the bearings and wanted to hear your input on how engine sounds. I am hard of hearing and I don't really know what fj62 engine usually sound like. I can hear maybe one of accessory(ac compressor, alternator or PS) whining a bit.
i see a 3FE ?
NOT a 2F in a FJ60
am i correct @Seth S ?
@3_puppies ??
i see a spun rod bearing for sure !
all this REVVING i killing any chance of Saving this 3FE ?
STOP NOW !
he says 62 series in this post
it is a 3FE
