Wanted FJ60 Manual
wanted: inspection light
I am looking for the FJ40 inspection light (courtesy light - the thing that plugs into the glove box receptacle) or a similar light that I could used instead of the OEM. Claudia
Claudia, I believe you can still get them from toyota New. 61370-80010 and it comes with the plastic bag or some of the retailers for like ~$25
call c-dan
I need some parts
One of the center caps for the 16" wheels that come stock on 2k1's
I also need that plastic cover for the spare tire in the back. (the one in the bumper, you pull off, so that you can insert the jack-adapter to lower the spare tire).
Both. They make real nice double knuckle arms. And it rounds out the upgrade of putting '60 knuckles on pre '79 FJ40s. I have a couple of sets of '60 knuckles handy but they are off of early rigs with the smaller arms.
Mark...
PM cruiserdan. He supplies the board with heavily discounted i.e. better than most anyone (minus Pimp) can get at a dealer. He works for American Toyota
My dome light doesn't come on when I open the rear passenger side door. It works on the other three though. It's the switch that has a little rubber boot over it to keep the water out. If you were sitting in the seat with the door open, the switch would be next to you hip inside the door frame.
Knuckle Spindle Needed for a FJ60
I managed to ruin the threads on my knukle spindle during my Birfield job on my FJ60. I thought I had all the tabs pushed back before I pulled off the 54mm nut but both the inner and outer turned together and gualed the threads up pretty bad. Does anyone have an extra, or know where I can get on for a reasonable price?
complete hardtop wanted
WANTED! a complete hardtop for a 1975 fj40. Must be in good to great condition. TOP DOLLAR PAID. Please no rust, or partials. Located outside El Paso, TX
tlburrow@aol.com
You have pm
egr valve 84fj60
i need a working used or cheap new egr valve for my 84fj60 2f. mine's stuck open i think and can't get it to budge with vacuum and carb cleaner.
you can email me directly also.
savearoof@aol.com
thanks
located in portland OR.
roof rack fj60 wanted
i need a roof rack for my fj60. full length. located in portland OR.
or email me at...
savearoof@aol.com
You have pm.
I should have a set of good ones. I'm located in Toronto,Canada. You may want to source these closer to home. Thx Mike
