Wanted FJ60 Manual
i'm in new castle, CO. i'd sell it for $200 or so. don't have pics now, but i'll see what i can do.
are you serious about us not laughing? that might be kind of difficult to hold back ;)
2005 Landcruiser Passenger Side Stock Running Board
Looking for a stock, passenger side running board for my white 2005 Land Cruiser. The running board is gray in color and stock. Need a replacement for my dented unit.
Thanks!
350
hey guys, im looking for a 350, to build up and drop in my 40. i live north of houston. is there anything i should look for or stay away from in a motor, my goal is close to 400 Hp and 425 Lbs, its just a goal though. my 2f is still good so i have all the time i need!
Grady
look for one in a weird vehicle like a short bus or something...better chance of one that hasn't been bored
New ConFerr bumpers on the shelf for $59.95. Shameless pimp. :grinpimp:
alittle more than a few hours from you, but I'll have an 85 up for sale here in 2 weeks. located in central MT all stock, minor trail rash, good interior
Outback said:
Kurt,
I don't have one for sale, but I have a tall 2F valve cover on my "F" engine. BUT!!! it has a press in rubber cap not screw on. Weren't only the '80+ valve covers screw in?? Someone enlighten me...
Jody.
Early 79 & later got the screw in cap.
I've got P/S pump that may need a rebuild. It had a "stiff" spot in the steering but I had a bad steering shaft. $25 + shiping if you're interested, I have all of the hardware that'll hang it off the block as well. I also may have the exhaust manifold, $25 + shipping again, no leaks. Here in VA.
PM me if you're interested
Chris
I have bellhousing (stamped 3F, not sure what that means, off an 85 2F) and used clutch assembly (pressure place, clutch fork, etc etc) if you're interested. $50 +shipping.
Chris
I have the valve cover off an 85 2F. Screw in cap, not sure if it's the "tall" one. The PCV? port near the back comes straight up instead of on angle. Let me know what to measure, I'd like $25 +shipping from VA.
Chris
Chris
Nope, I need the 1/79 - 7/80 Valve cover. Thanks for checking... :D
WTB: FJ40 Harness side of ign switch wiring
So I went to install my new ignition switch today and found to my dismay that a PO had hacked the connector off the harness for some reason and wired directly to the switch :confused: . Rather than chop the connector off my new one, I thought I'd ask here if anybody have a junked harness they'd be willing to cut this piece off for me? This is for a 77 and it has a 4 pin connector.
