Wanted FJ60 Manual (10 Viewers)
You can find the Power Steering pump on several different Toyota vehicles of similar vintage. I went to a junk yard and pulled one from a Cressida that was perfect...with reservoir for about $8. The bracket is the tough part. You also need a pulley! The bracket will be your difficulty.
Right. I need the bracket. So, identical i.e. cressida to fj60?
WTB: 4spd. shifter
Title says it all I'm looking for a 4spd. shifter if anyone has one they would like to get rid of let me know.
thanks
Burl
I have a relay rod and a tie rod, the ends seem tight, but the boots are shot.
I'm in Kansas City. Shipping plus $15?
Sorry, no drag link.
Ed
Co2 Mount
Looking for a Mounting bracket for 10lb. Tank....Powertank, Outback, or custom. Going in an 80. PM me
fj55 rear 2-2.5" lift springs...
thanks,
manny
77Fj40 gas pedal assembly
I am looking for a gas pedal and it's mounting hardware for a 77FJ40, I currently have a Weber carb. and the weber gas pedal, and am looking to go back to the stock set-up. PM me if you have one and let me know how much you want.
Thanks
JP
Trade ya for a 3 speed shifter.
I've got a drag link, center arm and relay rod I just pulled on a power steering conversion. Make an offer.
mike said:
Try spector offroad. Thx
The ones SOR has are new aftermarket for the 75 and newer. They do not fold all the way down to the anchors on the hood AND hold to the windshield frame; just one or the other.
I think he's looking for some good used original ones that have the two little L brackets where they bolt down.
orangefj45 said:
wow, mark is actually gonna cut loose of some of his loot?! :flipoff2:
Now now georg. You know I only hoard coarse spline birfs. :flipoff2:
65:
Pm'd you.
Thanks guys for the replies.
Go to a fire extinguisher store, they should have the brackets that you want. Generally cheaper than the others and many different styles
$15 at fire saftey shop
but I did find a new powertank brand mount 2 weeks ago at the swap meet for $5 :D
