Wanted FJ60 Manual (1 Viewer)
I've got one from a 91. two scratches in it, but the chrome piece on top is nice.
would one from a 91 80 series be the same, if so I have one.
You got mail....
The BJ74 never came with factory rear discs.
Check with G&S or Man A Fre or Specter.
Dave
G&S does have a Denki axle set from a late model 70 series sitting in the shop. It is electic locked front and rear, 4:10 diffs, electric hubs, however all 24V. It is not ours, however we are the broker for the owner. Contact Sheldon at info@gscruiserparts.com for more information if you want. I do not believe the owner wants them split apart however.
regards
gb
My plastic end cap in all dark gray with no chrome on, it so there must be a difference between the years? Or do you think its different due to it being a 40th Ann? Dont think so, but I could very well be wrong. I'm sure the later years are different when they moved to bigger flares.
Just an explanation to those unfamiliar with the Japanese term, "Denki" means "electric". What Greg has on hand is a set of 70 series axles with 24V factory electric lockers (plus electric locking hubs, how cool is that? :) ) These would bolt into the older 70 series as well and the 24V actuators will interchange with 12V models.
Dave
radio hole cover fj40
Lokkng for a radio hole cover for my 40. Anyone have one laying around they want some cash for?
Stealership price is way out of control for a piece of plastic.. :mad:
thought I'd try here before I use something else.
Send me an email I'll send you a pix of the one I have....at 16ltoy@msn.com
$75..
I cant see spending that much for a piece of ornamental plastic on a trail rig.
probably just gonnna put a piece of sheet metal in there..
2f Engine parts - Exhaust manifold....
I need several parts for my 2f. I need an Exhaust intake in good condition and the pass. side engine cover plate (not sure what the correct name is, has the X's stamped in the plate that I need).
I may also need a timing chain cover in good condition. Thanks.,
4 speed Transfer case
Looking for a 4 speed transfer case. I believe the one that came in 75+ year models?
Please email me at: roseauace@wiktel.com
or PM me, either way.
Thanks, Matt
