Wanted FJ60 Manual (8 Viewers)
WTB Military Trailer M416, M100 etc.. in Colorado
Howdy boys,
Im trying to track down a small (1/4 ton-3/4ton) tow-behind military trailer for my FJ40 in colorado, but cant seem to find anything close enough to pick up... everything is either east coast or california. Are any of you guys in CO, NM or Arizona selling a small military trailer? If not, could anyone point me in the right direction? Im looking to spend about $500-$600 and I will pick up.
Thanks,
Mike
91-? Fj80 Power Antanna
I am in the hunt for a new antanna for my Fj80. Anyone got one?
CMD82 said:
masscrusher,
what is your zip code? what did you have them on before? Did thet look too skinny? I know what 10.50's look like, but are the 9.5's signifigantly skinnier? Any pics?
Zip code 01463. They look good if the truck is stock height. They came out of my FJ60. Now I sport Trxus in 33"s.
Here are a couple of pica (I think the only ones where the tires can be seen):
It is the tan FJ60.
need OEM front/back hub caps
I am looking for a set of 4 hubcabs - 2 front with open center, 2 back.
Should be in good condition. thanks
antenna...
I was just @ Pep Boys the other day & nouiced that they had a bunch of different replacement antenna masts... that might be all you need... or is the motor not working??... the masts are pretty generic... I bought a BMW factory one for $22... for my Bimmer... so even even a toyota one can't be more than that... anywho... to replace them is easy... unscrew from the base of the mast... turn radio off then on... and the motor will spit out the remainder of the strap that it uses to push the mast up & down... then to install the new one, put that strap (of the new one) down into the base hole until it catches just a bit... then turn the radio off... the motor will pull that strap down... then tighten up the base nut... (OK now this is for every other power antenna I have replaced on different cars...so it should be no different on a yota...)... well, maybe you knew all this & i just typed your ear off... sorry if that is the case...
WS under gasket
WS under gasket is shredded
I need to replace the rubber gasket / weather strip which goes between the windshield frame and the body. The one the windshield frame rests on when in the upright position.
I see a new one in the internet for $184.00, kind of steep for a piece of rubber. Dose anyone know of an after market supplier or an alternative? I was thinking about making one out of neoprene but I am worried about it soaking up and retaining water.
Any Ideas?
WTB---Carb Base Temp Switch '78 2F
I need the temp switch that is in the base of the carb for a '78 2F FJ40
Like the one in the lower left of this picture:
i've got one in denver for $25 bucks. little bit of cracking on the back lip that sticks up, but rest is in great condition
I have a completely restored inside unit from a 79FJ40 along with the plastic heater duct to the blower unit - also have one of those (blower motor/housing) restored and ready to go. Was going to put this stuff on eBay but haven't gotten around to it - been too busy trying to build a set of half doors for my cruiser. I can send pics if you like. pm me if you are interested.
hey man clean it up and degrease it... the use some of that epoxy putty you kneed togeather... stuff works geat when it hardens.... also works on gas tanks... at least it'd work as a temp fix untill you get a new one
dan
Pm'd ya
I have a set. Will verify condition tonight and take pics if ya want.
Need FJ-60 parts, taillight lense, front part
Looking for the pass side tail light lense and the front plastic piece that covers the headlight, think it has a blinker or running light in it. I can send pics if needed. Thanks
Lee
jacobw_25@yahoo.com
EMAIL me at my email address and email how much you want for the parts.
Thanks
Damn. Slow guy checkin in here. The 67's no longer for sale. She's gettin cut into little bitty pieces next weekend. Using her to bring a 64 lv and 65 lv back to life. Won't be much left when I'm done either. Maybe a frame and title, but not much else.
mudmonster, did the project not get going? how far did you tear it down? I thought you got rid of a bunch of the drive train. Paul
