Wanted FJ60 Manual (4 Viewers)
I have everything that you need to swap from collum to floor shift 3 speed.....
PM me
I have a complete front heater (box) for inside the truck, doesn't include the fan, (which is separate and under the hoodl.) Should be able to do the emblems as well. Hit 40guy@prodigy.net in Texas.
cant you just use(swap) 24volt bulbs in a 12volt light? I know Hella makes most of thier bulbs in 24volt.
sbolduc said:
I am looking for a pair of 24V Off Road lights for my BJ42.
bump
The manual choke assembly will bolt to a DGE.
It isn't listed in parts but you could probably call them up. I bought all my Weber parts from them and haven't had a problem. Worst case is 399.00 new for a DGMS.
http://www.carburetion.com/Weber/weber.htm
Check e-bay under fj55. Someonr had a pair and I got the driver side. I think I saw the pasenger one there recently. There is a guy from New Hampshire parting out two pigs.
Hope that helps.
Mel
unless you're working with chip foose, i'd say that a "5 day full resto" is beyond impossible.
now getting a cruiser running in 5 days is more than possible.
FJ60 custom bumpers
looking for some burly bumpers/ bull bar type stuff.
want the rear to have a swing-out tire carrier.
HELP!!!
wtb 37x13.5x17
looking for a set of tires 5 to be exact. mtr's preffered but radial is the only important part.
Column stuff
I would be inersted in your old colomn stuff and the old tranny hump. I also have what you need and would be willing to work a trade, I don't have the soft top though. Call me 970 270 3332.
WANTED: Coilovers w/ 14-16" of travel
Helping a buddy of mine find parts for the tube fram set up he's doing on his '42 Willy's. He needs (4) Coilovers with 14-16" 's of travel. Used is fine.
Thanks!
Dash Grab bar
Just a shot in the dark here. Would anyone have a dash grab bar off a fj62 they would want to part with?
Thanks
Matt
Need Thrust Washers ASAP
I was hoping to install my new locker this weekend, but due to the welded nature of the spider gears, I need new thrust washers to pull this off. This is for the rear of a '70 fj40. The manual doesn't give any specs on sizes so I may need a couple options. I'd be willing to 2day this if posible.
1978 Fj40
I rolled my Cruiser last month and I need a windshield frame and hood. I have found everything else. If you have parts please email me back. I need to fix it!
Thanks, ZBM290
