Wanted FJ60 Manual (12 Viewers)
lift
I am looking for a lift for my 73 fj40.
I will most likly have a sized motor and good trany for sale soon motor has good carb and header I also have a rebuilt head (smogable). I am puting in a 4.3 and sm465 soon so if any one is interested pm me or email me at yosemitesamtlc73@yahoo
Early pig parts
Looking for a couple of early pig parts, and no, I'd don't need any pickled pigs feet.
I'm looking for a turn signal indicator from the early 1968-3/1969 fj55. Or at least just one plastic lens. They are the small horizontal lights attached to the upper fender/apron.
Also looking for a passenger side rear view mirror.
Thanks and watch out for random fence posts in the middle of no where.
need parts for '77 FJ40
I just wanna see what kind of availability we have on some of these items. Anybody got advice on finding these?
-Rear heater
-Plastic defroster vent
-Parts for a front heater
-Land Cruiser emblems
-Left and Right rear view mirrors
-more to come…
There are a lot of people out here that reside in CO, you should not have any problem finding any of this....
Try hitting nuclearlemon, treerootco, or some of the many others...
Good luck!
-Steve
Ive got a rear heater from a 73 55. I believe the only difference is that it has 3 bolts to the floor instead of 2. Its in good shape works well only thing wrong is a little surface rust. Let me know if its of any interest to you.
F motor
I have a F motor all taken apart with machined block new pistons rings and two good cams and two good heads. To be perfect you would need to get new bearings and machine the crank (it isn't scored or anything like that). Make me an offer..........ANYONE PLEASE IF YOU NEED THIS. 970 270 3332
Find your nuts....and bolts?
Looking for rear DS door fender flare.
I am in need of a fender flare for a 1993 FZJ80. I need the DS rear door fender flare preferebly in white...but ok if it isn't. Needs the be the fiberglass version and not the plastic kind. I ordered one from Cruiserparts.net, but they send me the plastic one and the mounting tabs did not match. Sending it back, but they don't have a fiberglass (1993) kind in stock. Please help!! :)
david
leaf springs
I was wondering if anyone has any lifted leaf srpings (about 2 inches or so) for a 72 fj40. They can be used or new doesnt matter
thanks
Adam
"I am doing a full out 5 day restoqration on a crusier for my brother so i can suprise him when he gets back from his trip."
" I have the tools, just not the know how or the parts."
Quite the task..
Where are you located?
Clutch for sale in Virginia
I have a good Clutch, Pressure plate and Flywheel for sale in Norhtern VA. I would like to get $40 for it. It will fit your 68 F motor and 3spd. I don't have the other parts, bearings, fork, slave cylinder.
Josh
I'm selling a new 4-6" Alcan Spring lift with brand new Warn Black Diamond XT shocks for $850. Its a big lift, and will require driveshaft and steering mods.
Josh
68 3-spd floor shifter and a soft top...
I want to convert my three-on-the-tree to three-on-the-floor. I know you can basically switch them out from the tranny hump (i already have the hump with the hole in it). Does anyone have a 3-spd floor shifter they want to get rid of?
I am also in search of a soft top, i have a hard top (and doors) to get rid of...
thanks,
Garvin
68 fj40
