FJ60 high steer q's
Dundee, Oregon
Is the high steer set up for toy minis the same as FJ60's? I know the pattern is the same and am asuming the tie rods are different but are the arms and ends the same? I found a set for a mini for a fair price with fj80 ends and dom rods so I am wondering if this will work by just buying the correct size rods?
thanks,
clint
yea it is the same for all the solid axle minis. 79-85 i beleive.
so yes it will work with the correct length rods.
I know with the FJ60 kit from MCI you get a mini truck pitman arm because the stock fj60 arm uses a larger dia rodend then most other Toyotas
