I am in the process of rebuilding my Transfer case.I dont have plans on installing my PTO because of right know my winch needs some fabrication done to it and also the headers im running does not allow room for the driveline..But in the future i would like to put the winch back on.If i put the pto gear back in the transfercase do i have to have the pto gear box installed on the transfercase? The used transfercase i purchased did not have a pto gear and there is a long spacer to keep the gear from sliding back and forth on the output shaft.My thinking is you cannot because the gear would be able to slide of the output shaft and may cause dammage? Just not sure.
Thanks
Brian
Thanks
Brian
