I just bought my first fj40, a 74, and its been being driven by the previous owner, who was the original owner, every so often to go fishing, but maintenance has not been kept up that well. The left front brake was the only one working and it would lock up the wheel when barely touched.
As soon as I got my new Toy home, I bought a disc brake conversion kit and pulled off my old front drum set-up. When I pulled the hubs off, there was no grease in them. One side appeared to have some differential oil lubing it and the other side was pretty gummy, but still no grease like I was expecting. Looking at all 4 bearings, they look fine and everything cleaned up ok and I'm waiting for the hub seals to come in before putting it back together, hopefully tomorrow.
Does the 1974 fj40 use a wet front axle? Are the front wheel bearings lubricated from the front differential? It looks as if differential oil is seeping from the hole in the end of the axles, but when I try to clean them out with a piece of wire, it seems like they are blocked. When I put the hub back together, do I just bath everything in 90 wt or do I pack with grease like most front wheel bearings?
Thanks for any advise.
Charlie
Charlie
