Hey, I'm not spam, just visiting from 200 series world. Was looking through some auto auctions and ran across this, figured someone here might be interested.
Interesting... Looks like a mostly original survivor. I noticed the unleaded fuel label on the dash, white spoke wheels and mostly intact seats. I maybe see original floor mat. I see the original console between the seats. Listing says automatic, but I distinctly see the four speed shifter intact. Looks like is has 86K miles. I can see that the steering wheel shaft cover is missing and looks like the key cylinder is missing. So, probably was stolen. Interesting that it says $17K retail value. That is a staggering figure seeing how much rust it has or guess some would call it "patina". That would make the original 1970 on this forum worth at good bit of money as well. Then compare them to this 1977 on BAT at $26K with 7 hours left. I'm guessing it will go in the upper $20s to low $30s. To bring the first two up to the level of the one on BAT would cost an arm and a leg.
The truck is in way rougher condition that either of the vehicles you mentioned. Screws are clearly missing, who knows how the engine runs, the rust could be deeper than either of the ones you mentioned as well (a lot of it looks hidden by crappy pictures, a big rust spot is clearly visible on the hood, and the frame is orange). It needs several thousands in repairs to be roadworthy no doubt. No way it sells above 20k unless some unknowing guy goes crazy in the biddingInteresting... Looks like a mostly original survivor. I noticed the unleaded fuel label on the dash, white spoke wheels and mostly intact seats. I maybe see original floor mat. I see the original console between the seats. Listing says automatic, but I distinctly see the four speed shifter intact. Looks like is has 86K miles. I can see that the steering wheel shaft cover is missing and looks like the key cylinder is missing. So, probably was stolen. Interesting that it says $17K retail value. That is a staggering figure seeing how much rust it has or guess some would call it "patina". That would make the original 1970 on this forum worth at good bit of money as well. Then compare them to this 1977 on BAT at $26K with 7 hours left. I'm guessing it will go in the upper $20s to low $30s. To bring the first two up to the level of the one on BAT would cost an arm and a leg.
Not trying to be a jerk, but this type of post should go in the classifieds.
