Fj-62 transfercase?
Fairfax, VA
Question for you guys with FJ-62's. Do any of you know if a transfercase from a FJ-62 with a 3FE will bolt up to a early 80 series with a 3FE to make it a part time transfer case? I have this posted in the 80's section, but not getting many replies.
Thanks for any input?
:cheers:
I think the fj-62 uses same trans as a 91-92 fj80 as long as its a automatic. (A440f) I believe? The 93 or 94 and up 80 series use the electronic controlled auto trans.
:cheers:
FJ62 is the same transfer case as the '85 and later FJ60 split case with some very slight differences. I do not know if it will hook to a 3FE but it will easily hook to a H55
