For Sale FJ 40 PROJECT
1972 Toyota FJ40 Land Cruiser. I do not know anything about the mechanical condition of any part on the vehicle. What you see in pictures is all that is included. As far as I can tell, it was a complete running vehicle at one time. For some reason is was partially disassembled and then abandon for several years. For the purpose of showing it's potential, I bolted in core SBC. It does NOT RUN or drive. The engine turns over by hand. The chassis rolls and steers.What I know about this vehicle is by visual observation only.
The frame is relatively solid. It does not have any rot holes but has some heavy scale and needs to be cleaned and treated inside and out. Personally, I would reinforce the frame in a few areas. The frame has been lifted by shackles and brackets but I'm not sure how much. Dual shocks on all 4 corners.
The tub is a fiberglass replica. Manufacture unknown. It is sturdy with no major cracks or damage. It has been lifted with 2-1/2" spacers. It shows signs of doors, seats, windshield and other body parts were attached at one time. None of those parts come with it.
The transmission is a GM TH350 that has been adapted to the stock FJ40 Transfer case. From what I have been able to find out, that adapter kit cost close to $600 plus installation. Front and rear drive shafts are connected and look in good shape. Front axle has WARN locking hubs.
Since it was set up for a Chevy small block, I took a core engine that I had from an 87 Camaro and bolted to trans and frame mounts. It's a Tuned Port 350 cid that has been dressed up and modified internally. I can only see that it has roller rockers and tube Headers. The right side header will not fit without some modifications to trans and collector. Nothing else is known about the engine. What you see is what you get. No starter, alternator and any other accessory. I used only half of a new high quality adapter kit to bolt the engine in. You may want to use the frame mount bracket parts that came with the kit since it's a better design and sturdier.
There is a Saginaw Power Steering box adapted and a pump. The pump is just hung on the block and not properly mounted.
The gas tank is a CON-FERR. I think it was designed as an auxiliary tank but I think it was the only tank used in this vehicle since the stock fuel fill was plugged off. The tank is rotted on one end and the skid plated is rotted in several areas. I think the tank could be repaired and the skid plate easy to fabricate. They are no longer manufactured.
There is NO TITLE. It has the original vin plate attached to the body.
Two sets of wheels and tires. The stock 15 inch steel wheels with tires that are dry rotted but hold air. I am including a set of 20x9 wheels that are multi fit pattern. Two 35x12.5x20 tires are good, two are not very good. I had to grind out part of the center to fit over the front hubs. I only did one to show the fitment. The other needs to be done if you want to use them. There are only 3 center caps but the front won't fit due to the hubs. The rears fit ok.
ASKING $2,000 CONTACT DAVE 609-418-5518
I don’t know how to post pictures here.
My avitar is one pic.
I have some on my phone. Do you want me to text them to you? Give me your number
Dave, welcome to Mud. Here is a link to your CL ad asking $1800.
https://southjersey.craigslist.org/pts/d/toyota-fj40-land-cruiser/6555230599.html
Mudders can be a tough crowd about 40s. Many of us are ... well, kinda fanatical when it comes to 40s, watch the market intensely, and are cheap ... (speaking for myself, anyway). Here is some info I hope is useful:
Chances are your 40 isn't a '72. Although it is tough to see, the rear crossmember appears to have the rectangular cutouts for taillights that were used 1974 and up. If it has (stock, not Chevy calipers) front disc brakes, the axle is '76 and up. I think you'll do better if you part it. If you're willing to separate, I may be interested in parts. Start a conversation (click where your screen name appears at the top right of your screen - the banner near the top of this thread).
There is another guy in NJ trying to sell a rolling chassis and is willing to separate axles, etc. Ignore his prices, he is dreaming. He bought it from a fellow Mudder ... and now he is trying to flip it and a bunch of parts to make a killing. Nothing wrong with making a buck, just be reasonable about it. His prices are not reasonable ... at all (IMO, YMMV). GL!
Thanks for the Help.
I wouldn't know a 72 from a 2002. In fact, I was so dumb, I thought I was buying a Jeep CJ until I got it back to my yard (I own an auto salvage yard) and I couldn't identify a thing on it. Then I found the ID plate FJ40129457, production date May 1972. And then I had to figure out why it had a GM TH350 trans and a Saginaw steering box in it. I wouldn't be surprised if the ID plate was from another vehicle. You are correct about the rectangular cutouts for lights. To me, the front calipers look stock. I don't remember and GM 2 piston calipers that looked like that. Again, there is no title!
Even though I'm in the business of parting out vehicles, I thought this would be worth more to someone who had the same vision of a pretty cool FJ40. I happen to love them. And given time and better funding, I'd like to build this one. Too many race cars right now. LOL
So the answer is, I'd rather not part it out.
Since you are in South Jersey, you are welcome to come over and take a look. We are EL&M Auto Recycling in Hammonton.
I think I know the guy he bought it from.:grinpimp:
