Hey all. I am in the middle of a rebuild on a 1982 2f engine and I have discovered that the crank keyway is in really bad shape. I have searched and read some threads where Mark W has recommended brazing the key in and fixing it that way. The crankshaft is at the machine shop right now, so I can't get any pictures but here is one I took while disassembling the engine.
It is hard to see, but you can tell that the keyway is worn.
I think it may be to worn to fix using the brazing method. What I need is suggestions from experienced people on how to fix this as replacing the crankshaft is not an option right now...
Could I have the machine shop cut a keyway on the other side of the crank, or is that a bad idea?
I will be stopping by the machine shop tomorrow to look at the crank, get sugestions, and tell them what I want done. Over the phone the machinist said it was not fixable...
