Fitting ssw Dakar beadlocks on an 80 series (2 Viewers)
North Carolina
Hopping on here to get some opinions. Read a forum about hub size on an 80 series being either 106 or 108. Mine is a triple locked ‘97, not sure the true hub size
Currently sitting on method mr305s
Tried to test fit fuel rebel wheels a while back and they would not fit the hub. Looking to buy a set of SSW Dakar beadlocks today that came off of a 3rd gen 4 runner, quick deal. My 80 isn’t with me so I am unable to measure. Wonder if they’ll fit?
Okay. 108mm wheels are the limit.
106mm wheels will not fit. I know this has been talked about before on here but I feel it is a common mistake made upon 80 series wheel options. Threw it into a fit guide and turns out they will not fit due to hub bore size. Also. If anyone wants a smoking deal on nearly new 17x9 SSW Dakar headlocks on brand new geolander MTs 33s hit me up. Hated to post on here to avoid the sticklers.
could always have a machine shop bore it out to 108mm
I have a set of wheels on my 80 that are advertised as 106.2. They fit fine. Guess I could take a caliper to them and verify. But likely what causes all those wheels to not fit is the ring inside that holds the centercap on. Most wheels that have bolt on centercaps and are advertised at 106.2 will typically fit on exactly. If I remember this afternoon I'll try to measure the wheels I have at home.
Realized there is no way to get the calipers in the wheel. 😅
Nothing short of taking the wheel off and measuring the rear hub.
And I don't have the energy for that tonight.
Its a pretty easy fix with a router and a flush trim bit if it's just the center cap lip. Obviously you lose ability to run the caps but most caps don't fit on 80's anyway
This ^^^
Been posted on here many times !!
Guess when in doubt just go test fit…..
Made 2 extra trips to go get my 80 before I let the deal go, didn’t think they would fit but…they fit! The rear center caps even fit, just not the fronts. -25offset on these. Just threw on some 315 KM3’s. So far. Big fan. 106.1 bore on these wheels, no issues at all
looks great!
