Hey all - gonna be digging into the rear axles this weekend to replace a bad bearing. Hoping this wont be a repeat of my cranky crank bolt job.
I've read the threads and watched the powermods video / terrain tamer vids too.
I've got a 54mm axle socket, so I'm going to fab it up with the notches to act as the sst for lock washer.
I got the full bearing/seal kit from cruiser outfitters. I've got grease. I got a couple extra axle studs and cone washers.
I'm not doing the brakes - PO had the rotors turned and pads at 9mm.
I'm gonna replace all 12 wheel studs too since some bozo used red locktite on one and it sheared off (I have a spare old lug nut and washer stack to re-seat new studs.)
I got a fish scale. I got the FSM pages printed.
Any advise for a first timer?
1> making sure the bearings are seated
2> to use rtv or not on the cones and gaskets
3> any traps or things that aren't obvious?
4> cleaning the ABS gear teeth...
thanks in advance!
thanks in advance!
