Anyone know the best source for a set of firewall grommets. From what I can tell on my 1962 FJ40 the two large are 46mm and the three smaller ones are about 26mm. Does that sound about right?
Check with @ToyotaMatt
Grommets and Plugs
www.cityracerllc.com
Grommets and Plugs
Matt you da man
I like the post on grommets. but one of the most difficult to find is the grommet located in the floor of the fj 40 that protects the lead wires to the gas tanks sensor,. this grommet is shared by a driver side seat belt wire. also going through the grommet under the tub. Anyone know what number is or where to find this illusive grommet? 1977 early fj40
Matt do you see me trying to contact you about my indicator lights? Can I please get a response?the OVAL or ROUND one ?
more then 2 photos would help here too ....
i have this going on now ......
it's simply bad to the bone heavy duty tough as nails pure period correct fit form & function Bliss ......
Parking Brake Cable Bracket Holder for Grommet Includes OEM Mounting Hardware 2/74 - 6/80 BJ40 BJ43 FJ40 FJ43 FJ45 HJ45 Part # 46453-60010 / 46453-60011 - VintageTEqParts.com
Parking Brake Cable Bracket / Holder for Grommet Made from Stainless Steel Includes OEM Mounting Hardware Bolts qty x 2 ...vintageteqparts.com
I have a couple of photos, but only of the grommet installed, I am pulling the gas tank to get them off of the vehicleI like the post on grommets. but one of the most difficult to find is the grommet located in the floor of the fj 40 that protects the lead wires to the gas tanks sensor,. this grommet is shared by a driver side seat belt wire. also going through the grommet under the tub. Anyone know what number is or where to find this illusive grommet? 1977 early fj40
I do not know if it is round or oval too hard to see it while it is installed, It looks like it may have two holes in the grommet. but the overspray of paint makes id not good at this point will have to pull the tank. thanks for your response,I like the post on grommets. but one of the most difficult to find is the grommet located in the floor of the fj 40 that protects the lead wires to the gas tanks sensor,. this grommet is shared by a driver side seat belt wire. also going through the grommet under the tub. Anyone know what number is or where to find this illusive grommet? 1977 early fj40
I have a couple of photos, but only of the grommet installed, I am pulling the gas tank to get them off of the vehicleView attachment 3806333View attachment 3806333
