Finally I began my coil spring conversion!! (1 Viewer)
Bologna, Italy
Website
www.fuoristrada.it
Yes! After months of late a few days ago I began the works on my FJ :cheers:
And obviously I'm right here to ask you some help...:rolleyes:
I'm now working on the front axle; today I put the bars (I hope is the right word...) in their position and I noticed that they are have a strong anglerespect to the ground:
Now: is that a problem? I mean, do these "bars" have to work parallel to the ground or are they ok also in that position? As you can see I put their connction on the top of the axle to avoid this problem...is that enough?
Thanx for your help!!! :)
Francesco
I know nothing about a coil spring suspension but I can't imagine you want the "bars" parallel to the ground unless you were fully compressed. How do you know what angle they will ultimately be at until you pick the springs you want and get the tires on? I would think that depending on tire size, spring rate, and attachment point will determine the droop of the bars. If the droop were unacceptable could you fab an attachment point that drops down off the frame more?
Good luck!!!!
Is the setup pictured at ride height, or fully extended ? If that is your ride heightn, and if it were mine I'd like to have the control arms a bit more horizontal, the way they are pictured right now will bring an awful lot of anti-dive effect which will affect the ride quality and braking stability, as well as a lot of roll-steer.
I would shoot for angles similar to what you can find on stock or moderately lifted LJs as far as handling goes. Make sure you weld the mounts aligned with the ride height otherwise you will have a lot of binding in the bushings.
To me is not difficult calculate the final highness becouse the coilovers are going to be done by a guy who builds coilovers depending on the characteristic you ask him to respect.
In the pics is not figured the final position becouse now the axle is not put exactly wher it should be, I can say that, when the cars will be finished, it will be a couple of inches closer to the car, so the angle of the bar should get a little better.
The road driving is not a big problem: I use this car quite only in offroad.
The idea of building attachment points much dropped from the frame is good, I just have to find a way to make them low and, at the same time, strong.
Francesco
The Bars are Radius Arms..
If your going thru all the trouble of this install, why Keep these?? They limit travel..
Id go for a 3 link Similar to what Action Jackson did to his 80..
http://www.actionjackson.com/cruiser/mods/20060110.asp
I think you will be much happier.. Especialy since you only drive it offroad..
In the end you will have a stronger, better setup..
isotel, on the front axle I'll use a classic system with radius bar and panhard becouse in quite complicated to build a 3 link; on the rear axle instead I'll use a 4 link o a 3 link with triangle.
Francesco
10 to 11* is not bad. How is a three link that much harder to build than a three link?
On a Radius, you really want the arms to be as flat as possible.
Mace a 3 link needs to calculate some things, is more difficult to build and I have engine and drive shaft in the middle...I'll see how it will come out from my work and maybe I'll think about buolding a 3 link! :rolleyes:
But I'm glad you're saying that 10/11° is not a bad data! ;)
Tomorrow I'll begin to build axle attachments for the radius...
Francesco
BTW, all of the angles, calculations still matter with a radius arm suspension. It is just that you are ignoring them..
with 2 radius arms ( control arms to me ) you can make a 3 link setup ... using the top link from a radius arm .. most if is only for off road use.
Mace, what do you mean? Are you saying that I'm ingoring some important parts of the work? :eek:
Do someone have some concrete informations or suggesting for a front 3 link? Tapage, you're saying that with these 2 radius arms (studied for a panhar) I can also make a 3 link? And the triangle where should be put? :confused:
Thanx again for you precious help! :cheers:
Francesco
that looks alot better,
the thing with Linked suspensions is their is alot of ways to do it, and no concrete type data saying "this is the way".. Im pretty sure a 3 link is the least complicated, Basicly you run 2 lower links from the frame to the mid point on the axle, then a Panhard and an upper link to control the caster angle..
So Aside from the $600 +/- you will have in Brackets, Joints Tubing and Treaded inserts, your only fabricating one extra piece being the upper 3rd link..
I like the way Action jacksons came out, and he did his on the same axle your using..
The radius ams look good where you have them as of now, If you go into the 80's section you can find alot of info on How they are trying to overcome the limitations of the radius arm setup and why it limits flex..
