Thanks in advance for any help, I studied the forum for weeks before diving into my desmog this morning. The good news it is ran this afternoon with a new "Trollhole carb" installed. Bad news is that I found a lot of vacuum tubes that were already split and disconnected, ran a little rough after install. PO had apparently done a small desmog previously.
So most of my questions are regarding existing vacuums or breathers that aren't hooked up and don't jive with Jim C's desmog schematic.
81 fj40- Trollholes carb has only single ported vacuum, I have it hooked up to inside port on dizzy advance.
Charcoal canister has three exiting tubes, one I assume is coming from the fuel tank. Second line, went to the Outer Vent Control Valve was rotted through, it used to hook to carb through the OVCV... should I just cap it? The third line leads to the VCV for the EVAP system. I kept the VCV... but it only connects to the BSVS and needs vacuum. Since I don't have any more carb vacuum ports I assume I should just cap second charcoal line, remove VCV and cap all BVSV ports? Or should I just hook one charcoal canister line to the intake manifold/carb base line to let it breath?
Crankcase PCV. Cap it or do I need a catch as some have described?
"Gas filter" on the intake manifold(not fuel filter). Has three lines to it, while capping two it just broke in half!! Any ideas on size of port so I can cap it? Is it the same as the BSVS valves, they look the same size?
VCV between dizzy and HIC/HAI. Once again, can keep it but it has a line to the above mentioned "gas filter"... if its broken can I just remove it and send all dizzy vents to airfilter?
EGR cooler flex tube. Cap it or remove the entire cooler. It looks like it will be a bear to remove due to severe corrosion. Any help on cap type or size?
I'm hoping some guys that put a Weber on (also only one vac port) or Jim C can help!! But I can't complain, its running at least!
75% of what I was unhooking has split lines, all the EGR tubes were rusted with holes and the previous owner had removed the air pump.... at least it made my decision to remove it all easier!
Forum rocks... the desmog wasn't that bad with the help.
Thanks Trollhole for a great carb and Jim for airrail plugs!
Cliff
Cliff
