Favourite Tool (5 Viewers)
The black ones are what I use to use, the red ones might be a new style to keep from leaking
Their website seems to show the ones with the orange bead being for sale.
so I'd guess those are the current version.
@Spike Strip helped me out. I have two Trail Tamer rebuild sets but I didn't get these inside the kits.
These are Trail Gear. I'm not sure where I got them, I suspect residue from Radd Cruisers being in Duncan?
Anyhow, I put the 2 new Trail Gear seals in today as the
first set was okay but with brand new axles going in just wanted to be sure.
Thanks for looking for me, as usual I get anxious about this stuff.
SS Exhaust work. Gorgeous stuff, I can dream. Found them trolling FB and looked up their old fashioned website. Neat stuff.
Borrowed this from my neighbor to pump my knuckles full.
I dunno. If they were 100 bucks, I'd own one, but they're more like 250.
Many moons ago I made something that'd push grease out as fast as a caulking gun. Think I'd make another before I bought one of these.
I bought one. Expensive and worth every penny. Shackles, u joints, tie rods, driveshaft and I got the cheap lockable fitting.
Dad has the Lincoln variety up at the ranch, it moves a lot of grease in year, not sure I use enough to warrant the cost at home though.
I have a cheap version of this 20 years ago... still works fine.
Westward $106 at Acklands.
Which reminds me I should probably pump some extra into my knuckles. If I did it as a day job I'd consider cordless... but since my 40 has onboard air, Ambo has a small Makita air compressor, shop has a small industrial compressor, and a spare Makita 2400 portable compressor. I never have a problem finding a compressor... even in the middle of nowhere.
I've got a 12volt one like that that i'm not using. Come get it, make me an offer... and beer...
Those cheapo clamp things are pretty slick.
Still not sold on the pump tho.
A few cranks here and there, no big deal. 4 tubes of grease in 4 cruiser knuckles? I was pretty happy to have a machine doing the pumping, but that's not something that happens all that often.
Lol, add up the fuel , the beer, and the other s*** I don't need I'd probably end up buying from you?
A new one is only 250 🤣
Yeah but it could always be worse. Could be horse trading for a rusty BJ70 and have it last two days!
Besides it comes with a matching 3/8” 12volt impact!!!
Latest contender… might be a bit early for this thread.
Picked up a Stihl MS390 for a song at a neighbour’s garage sale. It’s in very good shape. He said he only used it about six times and it looks like it. 4.3 hp and about 13 lbs. It’s rated as a mid range saw and seems to be well regarded. It looks almost new, but the gas is stale, the air filter looks clogged, and it probably needs a carb kit. It turns over when the cord is pulled. It has a decompression mechanism to make it easier to start.
Aside from grime, this is about the only sign of wear. The chain seems to stretched unevenly. It seems loose and tight both at the same time. I won’t know for sure until I clean it up and lube it. It’s not like a new chain costs much. It looks like it hasn’t been cleaned much. I hate to see tools so grimy.
It occurs to me that this saw hasn’t been used in a long while, and the chain may be getting tighter if it’s not flexing enough. If a section is trying to stay straight as it goes around the clutch sprocket the rest of the chain will get tight. This makes more sense than it being stretched weird… which was my first thought.
If it is sticking I’ll toss it in my pail of used (but clean) P/S FLUID and let it soak for a while and see if that helps.
Loooooovvee. My Stihl 034
Love My Shindaiwa 488. 10.1 pound professional saw that puts out 3.5 hp.
The Stihl Ms 390 is a 13 pound medium duty saw that is pushing 4.3 hp. a Bit heavier.
So far I've found that the needle bearing race in the middle of the clutch has melted.
