A bit too soon to call it a favourite but so far its shaping up to be,
Picked up an old Swan "made in Port Moody" compressor on marketplace for 100$. Single cylinder 65mm bore. Still had the operating manual attached.
I believe it was a dry pipe sprinkler compressor with a maximum cut off of 60PSI, so I replaced the pressure switch to a 125PSI rated one, oil change, cut an extension cord and wired it up... fired up right away.
10000X quieter than my crappytire mastercraft oil free comp, and should work much better for my needs.
I still am looking for a 20-30gallon air tank but in the meantime it works much better plumbed into the 3gal tank from my mastercraft than the mastercraft itself ever did.
Nice! Yup, with air compressors and pressure washer pumps, buy only oil lubricated! Lube free is not a good thing! ( .....
