Favorite Aftermarket 3 Gauge Kit for an FJ40 - Oil Pressure Voltage and Temperature
GRM
Finding new adventures in old jalopies.
Moderator
Livermore, CA
I’ve come to the conclusion that I cannot trust the old gauges in my 40 and need an aftermarket solution to keep tabs on my 2fe.
The gauges I think I am most interested in are:
  • Oil Pressure
  • Water Temperature
  • Voltage
I’m looking for help: I’d like to know what your favorite 3 gauge kit is for a 40 and how you hooked it up? Currently I’m thinking to bolt the 3 gauges directly below my steering column, but I am a bit lost what mounting plate will fit the best, and what kit has the right adapters to fit my 2fe.
I appreciate everyones help.
Why can’t you trust them? ....
check this out before getting craycray:
FWIW, My '76 FJ40 was showing low oil pressure over the last few years. The original sending unit was getting weak. The part is still used on newer Toyota vehicles. I replaced mine with a new Toyota sender and bingo, pressure back up from being just above the L. Pic is with the new sending unit and at idle after being warmed up. I would personally fix your factory gauges, not add more to the mix. Clean contacts, replace wires or whatever to get them in spec.
I do intend to fix the cluster at some point in the future, but right now I have higher priority issues to take care of of my cruiser. I need a temporary solution for gauges that can last a year or three.
I can’t trust them because of a few reasons:
  • The harness from the fuse box to the gauges is melted (in case you didn’t know: bolts should not replace a fuse when the fuse blows 🤦🏼‍♂️)
  • The sending units are mis-matched and its unknown if they work or not. Some are for an F engine, some for a 2f, some for a 3fe)
  • It is unknown if the engine harness from the donor fj62 has the wiring from the gauges to the sending units
For these reasons, I want to toss a couple aftermarket gauges at the 40, and deal with the remaining problems in the short term rather than chase gauge issues.
