I've never had the egr code yet
Lots of highway and 89 octane.
I'm sure I'll see it tiomorrow now
.Lots of highway and 89 octane.
.Junk said:Now have replaced every componenet and still get P0401. Next component to be replaced is the whole pos truck.
Rookie2 said:How are you trying to blow air through the VSV? I tried it by blowing (with my mouth) and about pop a blood vessle in my head, before figuring out no air was getting through. Then I tried a can of compressed air on it, and air went through. Anyways, I've go a modulator on the way.
Did you do the voltage across the terminals thing too?
R2
semlin said:turbo, your note has me confused. can you or can't you get the engine to run rough at idle with direct application of vacuum to the EGR? If not then I believe that means your egr valve is bad or else the port in the intake chamber from the egr valve to the main chamber is blocked. Anyway, if it does run rough and if you have verified all the FSM vacuum tests for the modulator, then I would check every vacuum hose and metal nipple in the system for vacuum leak, blockage or oily buildup, verify there is no blockage in the EGR ports on top of the throttle body into the throttle body, then start looking at the VSV or the temp sensor.
Junk said:turbo, Yeah, as mentioned, I have replaced every component at least once and most twice. The last thing, that was a few months ago now, was the valve. The old valve "LOOKED OK" but dude, I swear that since it was replaced all has been cool (note that now I am fawked since I just said that).
One issue I can not resolve though is whether or not the EGR system gets fawked during the blower install. With the supercharger, I know the vacumn does not work the way it did originally, but I can not figure out what exactly was changed. I did not keep the manual and am therefore up the creek yet again. Wish I had some magic wand, but my EGR system seems to be the maintainer of my karma.
semlin said:to clean the EGR ports on the throttle body you can either pull the throttle body and clean it (4 bolts) or just pull the air bellows and clean it in situ. I used a very tiny gauge wire to ream out the ports from the outside until I saw the wire inside the tb (I used the core wire from a twist tie I stripped). You can clean the tube in the intake plenum by pulling the egr valve and the throttle body, which gives you full access. Maybe an hours work. compressed air (even the computer cleaner can) helps, as does carb cleaner or similar. You will need a pipe cleaner or similar to clean the intake chamber port.
