Fan Clutch replacement - OEM vs. AJIK (blue fan)
fireball
southern VT
100 series friends,
I need to replace the fan clutch on my 99 LC. It looks like the OEM version is about $125. The AJIK blue fan clutch is twice that at 235 or 250 w/ hardware.
http://ajikoverlandexchange.com/products-page/landtank/100-series-modified-toyota-blue-fan-clutch/
Allegedly this will give me cooler engine temps and cooler AC temps. Is it worth double the price? Do I need this? I would consider myself satisfied with the current engine temps and AC temps. But sometimes you just don't know what you're missing!
TIA for any help.
I would say if you've experienced cooling issues or live in a desert climate, then it would be worth it to have a modified fan clutch. Otherwise, the OEM one's been working fine for me for 16 years and going (I just jinxed myself).
Fix it...until its broken :D Let it be...unless you're just dying to buy more gas.
Dan nailed it. Engine-driven fans are expensive to operate.
Sidebar: didn't someone (spresso?) come up with an all-electric replacement at some point a while back?
I was going to switch over to an electric fan set-up...but got sidetracked with other projects and life :D And at the end of the day I like the simplicity, albeit at a small mpg hit, and reliability of the mechanical set-up...
