I did my timing belt, water pump, thermostat and oil seals this weekend (Thanks guys for the step by step write ups in the tech section). As seems to be quite common, the bearings on the fan bracket just aren't as smooth as one would hope. A definite wrrrr noise when you spin it. I put the original back after seeing there was no easy fix other than getting a new one for many $$$.
As discussed on other threads, lots of guys spoke of seeing if they could press the existing shaft and bearings out and find off the shelf replacements. Now... I dont have a spare one lying around but someone on this planet must
This is a call to mankind... please try and press the shaft out and see if it can be R&R'd with new bearings... pleeeezeeee..... I'm sure brand new bearings would make our engines even smoother.
