Factory Subwoofer Info Guide (15 Viewers)
Nope. It works fine. Was just thinking "upgrade" lol
But if the stock amp can't power an aftermarket sub without issues then I'll just keep it as is.
The stock sub isn’t inherently bad. It’s looks a lot like a hifi sub (paper, low xmax, small magnet and voice coil). I bet it’s really high efficiency, and sounds good up to a point, which is where the stock dsp will roll it off.
Without changing the dsp, an aftermarket sub would be treated the same way, so I doubt much difference in the envelope. Like @Ratchey said, probably worse as the efficiency will almost certainly be worse on a bumpin sub.
It all comes back really to dealing with the dsp, either bypassing or replacing the factory dsp.
