The wiring is long enough you should be able to relo it out of the way, maybe mount it pointed downward like Slee does. If you ever tow, the trailer plug needs to go into the bumper, IMO. Factory location sucks.Still deciding what to do with the trailer wiring
no. its fully above the frame rails. i am hoping to put an air tank back in the space, the sub tank is sized to go above the tire winch, so there is quite a bit of space.The wiring is long enough you should be able to relo it out of the way, maybe mount it pointed downward like Slee does. If you ever tow, the trailer plug needs to go into the bumper, IMO. Factory location sucks.
You considering mounting a skid plate between the frame rails to protect the tank?
I chose not to drop the main tank. I did this outside in my driveway and didn’t have a way to extract the main tank from under the vehicle (or lower and raise it successfully).@grinchy I remember you posted the instructions for how to drop the main tank, did you end up having to drop it to install the fuel pump?
Thanks for the kind words. I made it more difficult than it had to be, but sometimes that’s the way of finding the way.Reading this thread is the closest thing I've experienced to my college Sanskrit class. The details are obscure, and yet here and there I find a few words I understand, causing a semblance of meaning to emerge... before it slips away somewhere behind my knotted brow...
I am envious of your skills and accomplishment here.
I joined a new forum Dual fuel sensors, one gauge - https://forum.allaboutcircuits.com/threads/dual-fuel-sensors-one-gauge.177573 and got some help on combining the fuel senders.
Success! We can put the two senders in series, and parallel with resistors to scale the readout accurarely for both tanks.
At EK1 (left side kick panel) build this simple circuit:
I don't think it matters which leg you put the sub tank sender in series on, but I chose pin 7.
The resistor values to parallel the senders with are:
A - 200 ohm - Sub tank sender
B - 850 ohm - Main tain sender
The goal is to parallel the sender potentiometers AND put the sub and main tank in series overall.
yes. The senders are inline Or ‘between‘ the two wires. So the factory sender is between wires 6 and 7. the sub tank sender is inline or between the two conductors I run up front.By putting the two senders in series, does that mean you wire pos of sender 1 to neg of sender 2, then neg of sender 1 and pos of sender 2 would wire to 6/7 in your diagram? With no resistors added you would read the cumulative resistance of the two senders combined, so between 30-820 ohms?
It has been a while since I learned this stuff in school, I don’t remember any of the calculations. Good work!
You need to sell these as NFTs.yes. The senders are inline Or ‘between‘ the two wires. So the factory sender is between wires 6 and 7. the sub tank sender is inline or between the two conductors I run up front.
ignoring the parallel resistors, we would see 30 full and 820 empty if the sub sender was added to one of the legs of the factory sender, (in series) It really doesn’t matter which leg as the potentiometer is resistance and doesn’t have a direction.
to parallel the pot, the resistors go between the conductors.
note you can make the purple highlight connections at once/same location , it will be easy to do.
I’m still waiting on the resistors, I’ll take some pics when they get in.
here’s a better drawing
edit fix a label, add second drawing
I had to do the math on this for it to make sense. It looks like this:yes. The senders are inline Or ‘between‘ the two wires. So the factory sender is between wires 6 and 7. the sub tank sender is inline or between the two conductors I run up front.
forum.ih8mud.com
Factory repair manual has ohms value (under testing sending unit for correct values). When I closed Downey, I couldn't keep my "one each of every manual Toyota ever printed", consequently I can't help you with this.
I am hoping it is at F! The stock gauge sweeps a bit to the right of F when full. 15 ohm on a 390 ohm sweep is less than 5% inaccurate when Full.The other thing to check is what 28.69 ohm would read on the gauge, since that is the lowest reading the circuit can produce that will never read completely full on the gauge since it is looking for 15 ohm.
