Factory split rims question? what kind of tires?
Always on the Run
Do i need special tires for my split rims? I want Goodyear MTRS 33 x 9.5 x 16 or 235 x 75 x 16. I know I have to get tubes and liners, but can i get tubes and liners for these tires I am wanting?
Rob
yes just make sure you get tubes for radials and radial liners....and bias tubes/liners for bias tires
you will have no problems
i am running 255/85r16 radial Toyo M-55's ...radial tube and radial liner...make sure you get the tube nipple off set....you are running stock-cruiser split rims correct?
255/85r16 is a true 33" tire and 10" wide
what is better radials or bia ply? I would think radials?
Rob
pros and cons of bias ply:
Cons:
bias ply...wear out fast
bias ply...get flat spots when sitting too long
Army tires usually have great sidewall...which means it takes a beatting...but...it doesnt flex all that well unless aired down ALOT.
Suck wet
Pros:
Usually cheaper than Radials
good on sand, dry pavement, and gravel
Great sidewall strength
Tube tires you can air down ALOT
Repairs on the trail
They look COOL
GREAT write-up:
Tire Choices
there is a good write-up here about split rims:
https://forum.ih8mud.com/40-55-series-tech/199121-255-85-r16-bf-goodrich-mud-split-rims.html
are you going for a vintage look?
radials are the better choice if you are DD the rig
pros:
smoother ride
wear alot longer
come in larger sizes
good pavement traction in all weather
better fuel economy
Cons:
side wall construction tipicly weaker
dont conform around rock as well as bias
usually a wide tire at the larger sizes
thats just a partial list
Not sure what you think of the kinda old school look but here is a swamper on my split.
Thanks fellas, looks like radials for me for it will be a daily driver, that last pic looks great but a little too aggressive for mine. I have 5 brand new 16" Toyota split rims for my 83 BJ42 LX RHD and will be going with 33 x 9.5 on my OME 2.5" deluxe heavy suspension. here is a couple of my recent goodies.
Thanks again
Rob
They are probably on the box somewhere, I bought them from 4wheelauto. Next time I go to my storage facility where my parts are I will check, you need?
Rob
