Good points made by all. Find an 80 with the factory lockers and be done with it.
x2
From what I'm told, if you have OEM lockers the passenger axle is different than a normal axle because of the sprocket that slides on the axle to lock the axle.
Any truth?
Do you have enough slack in the line?Ripped off the air lines a couple times on the trail
I had my non-factory locked 80 Series converted to factory lockers ... had to swap out the axles ... I purchased new ones but you can do it with used parts as well.
Big thing for me was the ability to take it to Toyota for regular service....so I wanted a system they were familiar with. Also, I heard the ARB's can more easily fail due to air leaks.
So what broke your lines? If you have appropriate slack, the airlines are run tucked away, and the back of the housing is tapped you should never have any problems.Yup, I cycled my suspension to ensure there was enough slack in the air lines. Didn't really need to worry about the front end though 'cuz there really isn't much travel there.![]()
ARB will engage quicker than OEM.
This comes in handy if you are in a difficult situation/obstacle.
screw both arb and oe electric and do ox locker. you know when it engages because the engagement is manual via a cable
I have never had a problem with the locker not engaging fast enough- it engages as soon as it is needed.
Sounds good, when I first heard of them I wanted them. Then I met a guy that has them. He says they are very hard to engage, adjustment is a PITA, and he wouldn't do them again. I would like to hear other owners' experiences- do you have them?
-Spike
I know you have probably gotten all the opinions you will ever want already, but after owning two of these, I would look for the nicest truck I could find with a good PM history. I would not worry about if it had lockers of not as there is a remedy to the problem (if you see it as one). I have had both and had no problems. Only thing I was ever concerned about was if the factory lockers failed....then it would be an expensive fix with toyota...but they never did.
