Extreme Land Cruiser 12" Lift
Anyone had any experience with this lift?
Pros and Cons from the pros on here?
http://www.youtube.com/watch?v=KG9crX23k90
http://extremelandcruiser.com/store/index.php?main_page=product_info&cPath=96&products_id=286
Extreme 12" Straight Axle Suspension Lift built 100% in the USA. System includes complete matched front and rear 3 link system , 4 control arms with Uniball uppers and double 1.25" Heims on each arm, 6" Lift coils and 6" perch drop/lift pads, Sway bar extensions, Panhard drop relocators. Shock relocators, Braided Brake lines, panhard bars using 1.25" Heims, extended front and rear driveshafts, new Z steering rod, plus all necessary hardware. Allows you to fit up to 40" tires with no body modifications under full articulation, or 44" with some body mods. Designed for extreme vehicle operation in mud, snow, sand, or other terrain not normally passable by a normal automobile. A truly out of this world lift that will set your rig apart from ALL other 80 series cruisers. Please allow 3-4 weeks fabrication and delivery time from the time of purchase. These kits are on a build to order basis. If you do not have a capable offroad specialist with quality welding ability, we recommend you send your cruiser to us for the installation.
This kit is also available in 6", 8", and 10" lift heights.
