well, that was interesting.
Still in the middle of replacing my water heater. Long story...
Anyway, I'm taking various pipes apart etc and then it dawned on me. There is no visible expansion tank in that system that I can see. So either it's buried in a wall or hidden in the attic or crawlspace someplace, or the plumber (I guess, if that) did not put an expansion tank in at all. So I'm amazed that the system did not fail long ago from overpressure. There is of course a pressure relief valve on the heater -set at 150psi IIRC- but I never saw that one release water.
Of course, that might explain why I had to change several toilet bowl valves over the years.
Then in addition to that: the main house water regulator failed. That will be a bear to change.
Moral of the story: check that you have a tank in, put a pressure gauge easily visible someplace and keep an eye on that once in a while...
