Hey all, I purchased a 2000 LC with 204K on the clock. Sat since 2016 or so. Cranks, but does not run. I am in the process of getting it up and going. Came across some interesting findings, and could use some recommendations.
Situation:
I was in the process of tracking down an electrical gremlin that is causing the 15A GAUGE fuse to blow instantly when ignition is keyed on (driver side fuse panel). I have been visually inspecting every wire and plug, checking for signs of where the wire harness was damaged, molested by prior owner, rat chew, water damage, etc.. Wire harness is pristine in the engine bay and cab...
I pull codes to see if any are stored, and OBD2 port spits out a P1760 code: "Linear solenoid for line pressure control circuit malfunction". Hmmm. I crawl underneath to inspect plugs around the trans, and come across this:
The plugs on the side of the trans visually appears though they were a wax candle, and burned. Wires, loom, and plugs all along the left side of trans are heat damaged. Wire harness running on upper left side of trans - also melted/ fused together.
The brake line fastner on the side of the frame - also melted like wax :
Its clear the wire harness experienced some impressive amount of heat from the catalytic converter... which is most likely plugged.
Questions:
Situation:
Questions:
- How would you approach fixing this? (attempt to repair wire harness from scratch? Replace harness completely?
- What other damage would you be inspecting for?
- Could the transmission be internally damaged due to this amount of heat? (in reference to the P1760 code?) Or is there a chance the damaged wires are making the ECU throw the P1760 code?
