Exhaust manifold studs...which ones (1 Viewer)
ERNRAM
Austin Texas
Have a 69 FJ that was actually built in mid 1968.
Going to put a 2F intake on it.
Which studs do I use?
Thanks
Ernie
@ERNRAM .
You have an F engine from 68/69 with an original head ( "early type head") to which you want to attach 2F manifolds (" later model manifolds")?
It would appear the "2XB" kit is what you need.
One question: does your head have threaded holes to the front of the no. 1 cylinder exhaust port and to the rear of the no. 6 exhaust port? IIRC, some heads don't and some 2F manifolds require them.
What are you using for exhaust manifold? I'm not sure how much mix'n match you can do with intakes.
