New or used spare?
Don't use it. Evil.
Try California!I agree whole heartedly. Unfortunately, gas with no ethanol is pretty much unobtanium around here these days. Last I could find, I'd have to blow nearly a half tank to get somewhere that sold non-ethanol.
If that were the case every vehicle in Arizona would experience these issues every time someone drove to flagstaffI found the heat source
It is just a matter of volume a 30 second off gassing would be the ambient air temperature and a bad CC. 10 minutes of off gassing and liquid fuel being spit out the full neck is a lot more than 120 degree sun.
I really think people are discounting exactly how much vapor is being released for how long in this thread. 10 minutes of off gassing is a very significant volume. In order to produce these volumes of vapor a significant heat source has to be boiling the fuel somewhere in the system. The difference in the boiling point of nonethanol gasoline and pure ethanol is only 7 degrees. 87 octane fuel boils at 180F at sea level ethanol at 173F at sea level. I would look for heat sources close to the gas tank to trouble shoot this mainly exhaust gaskets or damaged/missing heat shields.
Good to know. I was just saying that a tank off gassing for 10 minutes non stop with significant volume and pressure to force liquid fuel out the filler neck was requires a significant amount of heat. More than just a hot summer daySaying that gasoline boils at a certain temperature is telling only a small part of the story. The fuel in our trucks is made up of many different components with the lightest of them start boiling off around 100 degrees at atmospheric pressure and going up from there. The hotter you get the heavier the components will start to vapor off. The end point of your typical gasoline is around 400 degrees which means it takes that much heat to boil off all of the heaviest components in there.
If it wasn't so late and I wasn't so tired I would elaborate a bit more. But I run the console (think Homer Simpson) of 2 different units at an oil refinery. One of them is a reformer which takes in heavy naphtha with an octane rating of around 50 or so and bumps it up to anywhere from 85-100 RON, just depends on what the needs are.
Are you working on CCR? We have UOP unit that typical to 101-106 RON because the lowest grade of gas in Israel is 95 and we have 98 in all gas station mandatory. No ethanol (some times, some MTBE)
And we have summer and winter blends
@MaddBaggins you've done the most work on this. Any method you recommend??
