If a motor has excessive blowby can that blowby cause problems for the rest of the motor?
Can it cause a lean condition? That is, the MAF tracks the amount of air entering the motor. With excessive blowby, that is adding more air to the motor, just like a vacuum leak after the MAF. Wouldn't that cause a lean condition? Or because it exhaust gas, it will not affect the air fuel mixture?
If there is more pressure in the crankcase, where will the pressure go if the PCV system is overwhelmed?
On the 1fzfe's PCV system there is a intake vent (to let air into crankcase) and the pcv valve (to suck air out of the crankcase). This is how the PCV system works, right? Will any excessive blowby gas pressure be pushed out intake vent and into the throttle body?
I see some oil inside coming from the intake vent so there must be blowby gasses entering both the PCV and intake vent. The PCV valve is working. Would this indicate that I have excessive blowby?
