Better Crankcase Venting. Krank Vent?
North Front Range, CO
I believe I have more blowby than the PCV can handle. All the seals that were leaking when I got the 80 at 200,000 mi and stopped leaking when I switched to Rotella T oil are seeping oil very slowly now. Seepage also from oil cap and both PCV hoses on valve cover.
Did some searching and found a crankcase vent product called Krank Vents.
From what I understand, a Krank Vent is used produce and maintain a vacuum in your crankcase. You need to make your crankcase air tight for it to work (you block off the vent side of the PCV system). Its done for performance reasons but I would use it to see if it could remove excessive blowby. It is said with pressure in the crankcase the rings might not be sealing all the way. Maybe some of my consumption is from the pressure in my crankcase.
On a second thought, what if I plugged the vent port on the valve cover and just run the PCV valve? Would that work or do I need a bigger valve like a Krank Vent to remove the excessive blowby. Or, I could plug the PCV valve hose and use a larger PCV on the vent port. I will try plugging the vent method first. I will put a vacuum gauge on the vent port to see if I get vacuum. I should use vacuum/pressure gauge to check for pressure and vacuum but I dont have one. If that doesn't work, then I could try a larger PCV valve off the vent port. After that I might try a Krank Vent.
I thought you addressed this in another thread? Can you make a single thread or link to your other threads to a single one?
Oh jeez, it's like an infinite do-loop in here.
:doh:
:doh:
I had just remembered reading a thread a day or two before concerning the same type of thing and couldn't find it. Makes it hard to follow other's suggestions and commentary when "new" threads pop up.
I think I have several things going on at once that may or may not be related. In the other post I wanted to know if blowby gasses and the volume of added blowby would affect the air-fuel mixture. This thread is trying to deal with the affects of pressure in the crankcase like oil leaks, piston ring seal and oil consumption and how to remove the pressure. If the blowby gasses have no affect on air-fuel mixture then all I have to deal with is evacuating the crankcase, this is why I separated them. Guess I should of just posted "Dealing with Excessive Blowby" or "The Long and Slow Death of an 80" but, I didn't.
Gotcha. I was not trying to be a dick about it, I just could not find the thread and though it sounded redundant but I may have not grasped what exactly was going on in the first thread to realize this is completely different. Looking forward to hearing your results.
Right now I am doing some testing to see what affect blowby/exhaust gas has on the motor.
I somehow 'forgot' to hook up the PCV system and bumped the EGR system after checking my compression and for some reason I am only getting clean air, fuel and no crankcase pressure as its vented to the atmosphere ;). As long as I was so forgetful about hooking all that stuff back up, I may as well see what happens. I reset the ECM and cleaned off the oil seepage. I will see what happens over several tanks of gas.
I will later hook up the PCV valve and use it like a Krank Vent and use a vacuum gauge (my vacuum gauge will indacate a little pressure if there is any) a on crankcase to see if I am getting pressure or vacuum in the crankcase. If there is still pressure I will try a larger PCV valve (if they make one or try a Krank Vent. I am hoping that the PCV port on the intake plenum is large enough to keep up with the blowby. I may need to get a catch can or breather box and vent to the exhaust or back into the motor if possible.
As your rings are not sealing the combustion gases, the blowby is pressurising the crank case, I would vent to a catch can, run the oil back into the engine as the can fills. The PCV should not be overwhelmed by the blowby, if it is then IMO some major coin needs to be thrown at the motor.
Your comment that the leaks reduced when you changed the oil leads me to believe the oil in the motor was possibly contaminated with fuel? This comes from running over rich mixtures for a prolonged period, the resulting bore wash allows fuel into the sump breaking down and thinning the oil. the bore wash will also cause excessive ring wear, you can see where this is going right?
There is a theory that if you change the oil and filter earlier than recommended (perhaps every 4,000 miles) then the rings may 'bed in' a little making the motor usable for a few more miles?
regards
Dave
To clear things up.
I had oil leaks when I got the 80 back when it had about 220,000 miles. When I switched to T6 the leaks went away.
Over the past year the same areas are now seeping along with seepage from the PCV hoses on valve cover and they are held on by hose clamps and from oil fill cap.
I am going to switch to a dino oil and not do extended oil changes any more.
I have been using oil additive Liqui Moly Motor Oil Saver but cant get it locally any more, Napa quit stocking it.
This motor will not be rebuilt. When it goes I will either get a used motor or scrap out the 80.
The motor runs fine and its a daily commuter about 500 mi a week. I feel no loss of power, its just getting oil and needs some band-aids.
Mine is approaching 1/4 of a million miles, and by many high milers is not exceptional but, I change the oil way more often than it should be and expect to do plenty more. The very act of putting fresh oil in will help with leaks but, eventually the blowby will overcome any PCV, also now the seals will be hardening. There are chemical sealers out there which could be of limited use? They soften the seals around rotating parts allowing them to swell a little, if nothing else it may help awhile till you make a decision.
regards
Dave
What ever. Used motor or rebuilt motor, it is time to make a change.
If the motor runs fine I'd deal with blowby long before I spend $$$$ on getting a new engine.
I can go on and on about PCV systems. The krank vent wont help you in your situation. Mostly like your piston rings are not sealing the cylinder pressure thus causing u the blow by.
My suggestion to you since you dont want to rebuild the motor is this:
You probably have way too much pressure than your pcv system can handle. Cheapest and easiest way to relieve the excess pressure is to tap the oil fill cap, run a vacuum line from the cap to and oil catch can and tee it into the OEM pcv vacuum line.
