Ever use your wagon to max GVWR
Spokane, WA
So, the owners manual states that the Gross Vehicle Weight Rating is 8000#. The wagon is supposed to weigh in about 4500#, plus my rack at 120+/- and camping gear for four. I don't think that we pack light.
I'm going to borrow the neighbors 17' boat (open bow fiberglass hull) when we go camping. I think that I will be fine, just slow. I guess we'll see how the 2F-E handles it.
I don't think I'm too close to the max, I'm estemating 6500-7000#
Any one else really load down their cruiser?
I'll take some pics before we head out, just for poser status :)
It will pull it, but I'd be more concerned about brakes - if the trailer has electrics no biggie - but the cruiser has just enough for itself IMO as is.
I've towed bigger with mine, but in town and only for 10-20 miles max low speed (35-45 mph) otherwise I'll grab a work truck.
towed a 97 dodge stratus es from corpus christi tx to winchester va on a tow dolly...had zero probs starting from a dead stop to highway speeds and back to stop, in town towing, or hills & moutains on I81, in TN or VA......mileage didnt change much either..
i dont' know exactly about toyota but i do not most manufacturers(not just automobile) plan for about 40%-50% of actual ability. Thus when they say GVWR is 8000lbs it might be closer to 10,000 or 12,000 but i wouldn't plan on it.
lunyou
lunyou said:
i dont' know exactly about toyota but i do not most manufacturers(not just automobile) plan for about 40%-50% of actual ability. lunyou
huh?
Manufacturers don't rate something at maximum. Basically they know someone will inevitably load something to the maximum alloted weight capacity. So they will rate the (insert object here) at a lower amount usually around 80% of actualy ability so that when someone over loads the "max rating" they still have a bit of safety room.
So in others words: When they say 400 lbs it will really probably hold around 500 safely.
lunyou
Drove from Victoria BC to Southern Ontario with w/ a 2 axle u haul, filled with my bike, and everything else we owned packed into the truck and trailer. Reciept from the dump when we started out said we were 4800KGs
=~ 11,000 lbs???
Drove like hell through the rockies, prairies, n.ontario(mountains, flat, and alot of hills) Never had a problem with braking/stearing/control in any way at all.
Only got about 8mpg though...
my cruiser weighed in well over 5k when i took it to the scales and i've pulled a car trailer, with a 40 loaded full of extra parts, including a complete powertrain ...damn scary...decided i would never do that again. i've since pulled my 40 minus the trailer and extra powertrain and parts and that was ok, but i wouldn't want more than that.
lunyou
This is called a factor of saftey. Another example is in elevators. Look in one next time up above the buttons, and it will probably say a weight limit. The factor of saftey on an elevator is usually around a 2, meaning that if the elevator says that it's max is 5000 lbs, than it can hold 10,000 lbs before breaking.
I flat-towed a 3.2 tonne bus (7000lbs) with my hj60 one. that would be a total combination weight of about 5.4 tonnes or just short of 12000 pounds. it was a rather slow trip. second gear up the hills at 30kph. It pulled allright on the flat though.
you are exactly right, and explained it alot better than i did.
lunyou
I pull my 2500+ camper trailer regularly on long trips. The 60 pulls nice and straight, but I don't go over 60 mph. At that speed I'm about at max comfortable rpm (3000) and if I go too much faster sway can become an issue. Braking is excellent with the trailer brakes adjusted properly, stopping distance is about the same. MPG's around 13. I pull this with my wife and kid in the 60, and feel completly safe as long as I don't push it. I drive like a grandpa.
you mean a 60 series will travel at over 60 mph? ;) .....i have to get out and drive mine i guess.
lunyou
I recently towed a 2000 Passatt on a double axle trailer across town. Engine and tranny did fine. Brakes, not so great.
Most I've ever loaded the back with was 20 bags of quick crete and 5 sheets of plywood. Drove fine. Brakes, not so great.
My truck weighs 6200 packed for a weekend camping trip. Beer included. It does fine. Brakes, not so great.
there seems to be a pattern emerging.....you tow random things...
lunyou
