Hi guys,
Lateley I`ve been having gasoline smell in the car. It happens only on prolonged climbs (1-2h) and at heights (between 1500 and 4000 m). From what I`ve checked in FSM EVAP system sucks the vapors into the manifold only with hot engine and RPM above 3000, so my theory is that with prolonged climbs (L or 2, 2000 RPM max) the carnister gets overflowed and cannot store any more vapors. Can it be so or the capacity of the carnister should be much, much higher? Any of you had similar problem?
Should I forget about the issue and release the vapors manually (loosening the hose going to carnister or opening the fuel tank cap?), change the carnister or maybe install one more in parallel/inline with the existing one?
I`ve checked the EVAP as per FSM and the system behaves as expected (although the sucction above 3000 RPM with hot engine isn`t super strong and blowing air into the carnister requires some effort).
Any advices?
Cheers from Cordillera Central in Colombia,
Bartek
Any advices?
Bartek
