That sounds about right for a electric car.My stock 94 80 weighs 5100 with me in it. My Tesla Y weighs 4800 with me in it.
Not getting into the materials et al. That's a can of worms for the chit-chat threads.
Drivelines have come a very long way in the last 30 years. Big power, much stronger components, more reliability, more complexity, more tunability. Nothing about most competition trucks is factory, and hobby trucks are deep in the aftermarket parts bin. Many of them are running aftermarket controllers and software. None of them are connected to the cloud to enable hacking and what not. EVs will be similar. It'll be very cool to see what people cobble together and what trails they'll be able to run.
Safety is a thing. Gasoline has issues. So does propane. EV has its own issues. But every fuel powered vehicle has a risk. The user assumes that risk upon themselves.
Don't get me wrong - I'm a tech head and I like EV tech from a pure technical standpoint. But as an industrially experienced pragmatic person who operates and drives heavy machinery for a living (freight trains) I realise that the way EV's are being pushed and marketted is at the expense of safety.
There are already isolated cases of EV's connected and charging unattended at people's homes catching fire resulting in full-structure involvement and potential loss of life. This is going to be a much more common and regular occurence and in any multi-occupancy residential setting the risks are amplified significantly. You can't suppress an EV battery fire by dousing it with water from sprinkler systems as it simply is not enough. You can't shut off the airflow into the enclosed space of a car parking area to put it out as the fire self-sustains by breakdown of the lithium and cobalt battery substrate materials. The reaction has to be stopped by total immersion in water to reduce the temperature below about 200 C, or let it burn until all the materials are fully consumed and burnt out.
EV's are like any other battery-powered device - the biggest risk is when charging, and the penultimate part of this is *unattended* charging! How many people will be 'sold' down the EV route then just 'plug in' when they get home, and forget about it until they 'unplug' later on (next day generally for office worker, retail, and similar commuters). No devices should be connected to power charging in a residential setting when either unattended or the occupants are sleeping. EV's are no different. This very different to an electrical device like a TV or fridge or microwave or your internet router/modem as none of those devices have internal batteries being recharged from the grid or other electricity source.
Rapid uptake of EV's means rapid introduction of unregulated fire hazards specific to EV's into all residential and business environments. EV fire hazards are very different to those presented by petrol and diesel powered vehicles. The toxicity of EV fires is 10 fold greater. So yes EV's are technically good for suburban air quality, just burn enough of them and there won't be much difference to what we have now except the composition of the toxicity of the latent air mass will be different.
Now I'm not saying EV's are 'bad' - they're not. I think in pure medium to high density suburban residential areas they will be beneficial.
Getting back to specifically EV ute's and 4wd's, for Australia (and perhaps the USA too) they are not practical for any heavy duty commercial, off-road, and/or towing tasks. Not yet.
All mainstream 4wd and ute vehicles here bar a few are now marketed heavily around being able to tow a load up to 3.5 tonnes. This is aside from the fact that towing any load heavier than the vehicle doing the towing is inherently dangerous.
Lets say your typical EV ute and 4wd has a stated range of 500 km (currently none exist here coming anywhere close). Stick a typical towed load such as a loaded car trailer or a big off-road caravan or camper trailer weighing over 2 tonnes. Immediately you have reduced your range on a full charge by more than 50 pct, probably more like 75 percent or greater. That means more frequent and *longer* stops because each stop requires almost a full recharge and remember recharging is when the risk of EV battery fire is the highest. So you'll almost spend as much time stopped than driving. Recharging to less than 100 percent to get going sooner is also a zero-sum game as you don't win!
Tradies will see this too - a basic ute when loaded up with all the gear and equipment has a much higher mass, and more mass requires more energy to make it move.
Note I'm ignoring the technical aspect of regenerative braking, and I'm also ignoring the fact that almost be design an electric vehicle has no way to deal with what might happen if regen braking input exceeds the charging theshold of the battery module then how is the excess energy disposed of? On diesel locomotives, dynamic braking (regen braking but the energy isn't 'captured') disposes of the braking energy from using the traction motors in reverse as heat in resistor grids that are fan cooled - there is no technology in existence to convert electrical energy back into chemical energy in the form of diesel liquid fuel as once the fuel is burnt the energy is released and tranformed into mechanical energy in the big diesel motor (then into electrical energy then back into mechanical energy then lost as heat). Nobody disputes that all internal combustion engines are technically 'inefficient' machines.
Heavy rail transport (in Australia) has pretty much gone away from electric locomotives (except in QLD with it's 25 KV AC system) where regenerative braking fed power back into the traction power system and (theoretically) powered other trains, but that rarely works in reality. In motor vehicles there are a bunch of factors which mean it will almost never occur that regen braking inputs to recharge a vehicle's battery module will ever exceed the unfulfilled 'empty' charge capacity that's been used for 'energetic' driving (ie. using the traction system to positively propel the mass).
As you can see I'm not simply saying that because of the Cult of Electric Jesus Christ (Elon Musk via Tesla) evangelism that EV's are EVil (lol). They are technically excellent uses of technology, just very rushed and badly thought out in the domain of safety. It's the standard 'arms length' approach where all the risks are being hidden away from public view - until they're not. Plus all the talk of 'zero emissions' is a complete lie!
