Engine
Ok so today after some 2.5 months I am supposed to be getting my truck back. The final damage was that the block and oil pan split, as well as, seizing of starter, alternator, ac compressor, break calipers etc etc.
It now has 2002 Tundra Engine Swap with way less kms than my original one. On top of that, it received tons of new parts and accessories, as well as, transfer case, diffs and transmission inspections.
Seems like the water got quarter way up into the doors but did not leak into the interior.
Anyways, I will be stripping down the door panels, and lifting carpet, at least around the edges to access the damage and trying to wash off as much sand/mud as possible.
Also, I will be removing the wheel wells plastic arches to inspect and wash out any mud that might be sitting on the insides of the panels.
I am actually very paranoid about this now and not sure if I can even enjoy my vehicle again.....as far as im not sure if I compromised the reliability of an LC for the rest of its life and I will have things popping up that are wrong here and there from time to time and depending on weather/moisture/cold/heat etc.
Any opinions or other measures I should take to prevent problems in the future?
If you're that worried about it, sell it. I can tell you I would be fine w/ those parts on my vehicle. Water damage is not that bad if it stays out of the critical electronic components (dash). Even if water got into the carpet, it's just water. Water damage can be cleaned easy enough.
In a nut shell, my attitude is "if it runs, it runs". Give it a good test drive (4x4, lo vs hi, ect) and if all is well, just pat yourself on the back for saving $6k+ by paying out of pocket.
I assume you have some type of warranty from the shop? Again, do what you are comfortable with, but in this scenario I'd drive it til the wheels fell off and enjoy the slightly lower miles. Other than selling it, you don't have any kind of recourse w/ the insurance company. I say it's a great time for a serious off road build!
Maybe you already posted it and I missed it...but who ended up paying the bill, you or the insurance company?
I didn't see it either but it sounds like insurance paid for most of it.
The bigger question is. I have a camping trip 10,000km trip from Alberta to San Diego and back. Through Death Valley and all.
Would you guys be worried about driving the truck 30 days after an engine swap. And partial water damage considering I will clean it and most of the truck has been gone through.
If that thing breaks in Grand Canyon I swear I'll be so pissed off ill leave it there and you can grab it for free lol
That's a tough one. I would probably drive it like I stole it for a couple weeks just to make sure there were no rattles or bolts trying to work lose. I might even run it back to the shop for a thorough inspection prior to leaving. If all is well, enjoy your trip!
About 25 years ago we ran off the road and completely submerged the front 1/2 of our 84 Celica GT. Entire engone, dash, front seats, etc under water. Car then sat for two years. Finally being 16 I decided I was going to make it run again. I did a fluid flush, bought a new battery, had to replace the starter and get the radio fixed. That car ran another 15 years until it finally had an oil pump failure.
Point being Toyota does the engineering right and the LC gets built better than the rest. If you had a reputable shop do the work and you trust them... put some trust in the rest of the rig. Especially if you are confident the electronics stayed dry...
Thank you for your story. That's a very good point.
So I got the truck.
It drives fine but I think the muffler got some mud/water in it. When I step on it, there's a cloud of white dust behind me. I'm thinking I should get the Cat back system from edms.
Question: is driving the truck with somewhat of a restricted flow in the exhaust system would cause potential engine damage?
Yes it can cause damage, but it would have to be a lot of restriction. If you're blowing white smoke, it's just burning old carbon build up off...no need to worry. It should go away after some spirited driving.
Do you think water could get all the way into catalyc converters? I'm just wondering if replacing the cat back would be enough.
I guess it could, but there is a vacuum that helps keep water from getting too far in. I wouldn't think a little water would hurt but a full cat back system would certainly fix anything water hurt.
